90 K5 power steering
Ralph the german
Registered Member
Germany
Hi guys,
need again some help. Does anyone know, that the ´90 K5 power steering fits a ´77 Cheyenne PU ?
Thanks for help
Yes and no
If you swap the pump, box and all the lines they will swap over.
If you swap just the pump OR just the box, the lines will have a flare fitting on one end and an o-ring fitting on the other (i.e. you'll need to have a hydraulic shop make you a custom high pressure line).
