'91 burb R2500 to K30
91 burb build
The old man @bigblock454 has made me the proud new owner of his sweet 91 big block 3/4 ton burb:cool1:. Unfortunately I was born with exactly zero leave it alone in my blood so the off-road design 2wd to 4wd front hangers are already here, got them on the 'merica day saleflagwaver along with rear shackle flip and super shackles, motor mounts, steering box brace and whatever else I forgot I ordered....Ill be ordering ord leafs here at some point, and stuffing the kingpin 60 in it that gm should have... the source of the 60 is undecided, either robbing it out of my 99 6.5 k2500 sas rig that hasn't moved in years or my axle rack that has a crusty dually 60 in it somewhere. the block of bigs is here to stay, the 4l80 is here to stay(my left foot is lost), may run a divorced 205 so I don't have to touch the trans idk yet. aiming for 4'' lift and 35s to match my 91 k5. There's zero rot on this bad larry, only rust is surface on the roof since the paint got up and left, Ill be taking a stab at painting this unit, figured its a smart choice for my first automotive paint job to be a 50000 sq ft 2 tone dual metallic job.... :1zhelp: good thing these 2 colors are budget friendly at 820$ a gallon. Id really like to get the ac going again considering the air here in Indiana has the consistency of mashed potatoes. any suggestions on upgrading from the shit r4 compressor and getting the rear ac working again appreciated. a matching bumper set to my k5 will be in the works eventually and rock sliders probably made of 2x6 or 2x8 rectangle tube to be steps and kinda match the vibe the running boards had that we peeled off years ago, frame tie ideas appreciated. A baseline overland roof rack may be in the future if I can bring myself to drill the required holes. The overall purpose of this unit is to be a badass go anywhere tow pig that's comfortable to pilot and ready for cross country trips. No wheeling intended, just 4wd capability for remote roads. Ive been getting into going to/volunteering at ARA rally races and have been on washed out roads that require 4wd to recover rally cars. plus what looks better than a 60 under there? This will be my first sas with a 2 post lift, to say I'm excited is an understatement. constructive or destructive critisism appreciated, welcome to another episode of too many projects
Some minor updates and future plans, May have gotten the intermittent dieing issue solved, we found that it has been running solely off the fuel pump relay, which was fine on and off, it didn't have an issue for probably 6-8 months, then died 3 times in a 2 day span. loosing the fuel pump relay, still unsure why, but now it has a functional oil pressure switch/sender and now I can unplug the relay and it stays running. Hopefully that's the end of that issue.
The torque converter still dosent lock on its own, but there is now a toggle switch wired into the ALDL, I've just been leaving it locked and it seems happy enough with that, locking in 2-4 dosent bother me. I presume it will stay this way unless I find the 4l80 cares for some reason.
2027 developments.... I have stumbled into an opportunity to combine vacations to have 28 days off in a row end of July-august.I have decided the best use of this is to light a fire under my ass to get the burb built and drive it from Indiana to Prudhoe Bay Alaska. You know just a 10k mile roadtrip on a fresh build, seems logical to me... So with this development I have a few decisions I need to make and get things rolling.
I have the above stated ORD parts. I would appriciate suggestions on the available engine crossmembers as I forgot that I won't have one of those when I rip the 2wd stuff off. Im torn between the ORD crossmember and the CFMindusties. the most notable difference to me is the CFM has the motor mount surface included, my understanding is I would have to source that part from a 4x4 frame for the ORD crossmember. I also wonder about the CFM crossover clearance as I'm wanting to be in the 4-5, maybe 6''lift range with D60 and 35s. I want just enough room for 35s turned with some flex without cutting my nice fenders.
Next big question is Shocks. I will likely get ORD extended length shock mounts for the front, but Im not a shock guru, I don't know what brand or series would be best suited to my build, I am aware that I will have to compromise somewhere as there isn't a one perfect choice for a multi purpose vehicle. this thing will be reasonably heavy im sure, bumpers, winch, sliders, swing out rear bumper, roof rack etc. It will tow, have a hitch carrier for a dirt bike sometimes, maybe even on the front if I think it's feasible, it will see light trail use, more in the realm of overland stuff, the majority will be street, and gravel stuff. Im happy with the Bilstein 5100s on my k5 but it is considerably lighter and hasn't seen lots of high speed washboarding and that kind of thing. Im sure the Alcan, Dalton, Top of the world and potentially Dempster highways will be severely taxing on the shocks. and whatever else I come across in 10,000 miles. Im assuming my goals are in the remote reservoir territory but that's far from my wheelhouse, so any recommendations here would be greatly appreciated.
There will likely be more questions to come but this I feel is a good place to start, Thanks fellas
Factory clamshell mounts with energy suspension poly inserts will bolt to the ORD tubular crossmember, at least can confirm on my small block, but not sure if they make a version for 2wd -> 4wd, looks like CFM does.
Shocks, I’ve got 5100’s also and not sure there’s much room for improvement until softer springs are installed. Are you going to try and get ORD springs installed before the trip?
The part I will be missing for the crossmember isnt part of the motor mount, I have ORD motor mounts already, the missing piece to my understanding is a portion of the oem 4x4 engine crossmember, the upper part that goes from the top lip of the frame rail down to the crossmember that the motor mount bolts to, but I could be wrong, I need to look in there and see what I have with the 2wd stuff.
I think my plan at minimum is to get ORD front springs, my k5 has a 52/64 swap with gm springs and im reasonably happy with that but I want it as good as it can be without going full coilover. I will probably need rear springs too and with the lead times I should probably just order a full set
