offroadblazer764x4
cant wait to see how it turns out
76 k5
76 k5
Nice progress! I have never seen an exhaust routed like that! Thats crazy!
This is a good question that I believe ends up being personal preference. I would say yes to using the CUCV MC because it was designed to be used with those brakes. The catch is that the hydroboost may complicate a hydraulic assist type of steering set-up that you may want to put in down the road. If you are ok with your steering the way it is, go with the CUCV set-up. If you are looking into hydraulic assist steering, you way want to explore other avenues.
FWIW - I bypassed the load valve on the rear brakes and it worked fine. With bigger tires, more brake pressure is a good thing.
Well, Its a diesel so I've got hydro boost brakes already and my steering box is tapped for hydro assist. I haven't installed the ram yet but that is coming soon. What do you think?
the angle on the shaft isnt as big a deal as the angle on the joints
