I just bought a 71 GMC Jimmy that sits on a cut down 91 Dodge 3/4 ton frame. The truck has a Cummins 6bt with a NV4500 5 speed Manual Trans. The guy who did the build seems to have gotten it running and looking decent and stopped there. There are ALOT of little issues
. I plan on going through the truck and cleaning up alot, installing new rubbers, Roll Cage, Soft Top, and new interior. Other than that I jsut want to get the mechanicals that are there solid.
Issue 1:The transfer case isn't like the GM's and doesn't have a name plate. Does anyone know what it would be? Also when I try to put it in 4-wheel drive it is extremly difficult. Is there some thing I should check because I am assuming there is a linkage problem. It also is hard to take out of 4wd once it is in and I can here the front drive shaft turning even when it is off. One of the difficult things of buying a truck like this is I have no clue what is normal or what position is what on the 4wd gear shift. I assume all the way forward is 4 wheel Low, then one back is neutral, then one more back is 2wd, then all the way back is 4wheel high. I am not sure but that is what it seems like when I try each location. If anyone has any advice on this transfer case it would be greatly appreciated. Also I would like to eventually go to the NP241 Does anyone know if that is doable?
Issue 2: The steering is a death trap. I have read alot about the Dodge's having steering problems. Is there anything I can do Cheap to make it better now? Also I plan on changing the steering to something better. Is hydrolic steering worth the money or does someone have a better solution. I plan on doing some wheeling in this truck but don't want to F it up either so I won't go crazy.
Issue 3: I have changed the oil, batteries, and belt. I want to go through and change all the fluids in the Dana 60 front and Corp. 14 rear. Should I change out the fluid in the NV4500. I have been told it isn't necessary like it is in a auto trans. Is that true? Also what fluid would you put in the transfer case.
That is it for now. Thanks for the help.
. I plan on going through the truck and cleaning up alot, installing new rubbers, Roll Cage, Soft Top, and new interior. Other than that I jsut want to get the mechanicals that are there solid. Issue 1:The transfer case isn't like the GM's and doesn't have a name plate. Does anyone know what it would be? Also when I try to put it in 4-wheel drive it is extremly difficult. Is there some thing I should check because I am assuming there is a linkage problem. It also is hard to take out of 4wd once it is in and I can here the front drive shaft turning even when it is off. One of the difficult things of buying a truck like this is I have no clue what is normal or what position is what on the 4wd gear shift. I assume all the way forward is 4 wheel Low, then one back is neutral, then one more back is 2wd, then all the way back is 4wheel high. I am not sure but that is what it seems like when I try each location. If anyone has any advice on this transfer case it would be greatly appreciated. Also I would like to eventually go to the NP241 Does anyone know if that is doable?
but that's just GM, I'm not sure if Dodge ever used one in 93 or back trucks that would adapt.....maybe.
