aj's tonka truck
- Joined
- Jun 29, 2004
- Posts
- 53
- Reaction score
- 0
Which wheel studs should I install so I can run mag wheels which are thicker than steel wheels. I checked out the DOR-610-301 studs which are 3 1/4 in. long with a 9/16 thread but the part store said they showed them to fit a Ford axle. The stock GM studs that camd with the 14 ff with brake drums are 3 in. long and the heads are larger than the DOR-610-301, but the dia. of the shank seem the same. I have the 3/4 ton disc rotors for a 85 GM truck. Please, I could use some help with this. Thanks !
