91 K5 stuff plus ORD Brace and Dana 44 Gussets (WANTED STUFF ADDED)
74kay5
San Jose CA
Misc
Front pair of bushwacker OE Style fender flares for 00-07 chevy tahoe $150
K5 Jimmy Suburban specific
Skid plate for NP 208 NP241 transfer case (have 2) $25
Radiator $50
front driveshaft $40
Rear Driveshaft $50
Brake Booster, and brake pedal assembly $50
Polyurethane sway bar bushings $15
Oil filter sandwich adapter for oil cooler SBC $25
U bolts for 4" lift springs with nuts and washers $30
Pro Comp 4" lift Springs with bottom leaves removed 2.5" lift??? $75
Skyjacker 4" lift spring main leaves (good for replacement for sagging or cracked springs). $30
OEM Front Brake calipers with fluid still in them $35
Tie Rod hollow type with jam nuts and TRE's (hard to find these days). $50
Shock inboarding brace with hardware $75
LS1 LQ4 stock and aftermarket parts:
6.0L swap engine crossmember $250
FULL ALBUM OF PICS!!!!!!!!!!!!!!!
http://rides.webshots.com/album/62332864pLFFIT?start=0
WHAT I WANT:
Longer front driveshaft than all the stock ones I'm trying to sell
Custom tube or plate rear bumper
Rock sliders
Roll cage, partial or complete
Someone local to Northern California to help me weld up some stuff because my mig welding looks like something a bird would leave behind.
I am assuming the "ORD Brace" is the bolt-on steering box brace for '81 to '91.
If so I am very interested. Pics?
what do you think shipping would cost....ball park? Would you take $30 for the part?
sounds good. I will definatly take it. How do you want me to get the money to you? Let me know what we need to do to work it out. If you want, give me a call 214-837-9075. My name is JD
Sent you a PM
