The thing is - sometimes an auto will spin the output a little in neutral. There's not enough torque to make any difference with the driveline engaged but with no load at all it will start to spin. This can cause the grinding when shifting between 4LO and 4HI. If the vehicle isn't moving, then grinding doesn't tell you anything about axle ratios.
But there should be no grinding when you shift into 4HI from 2HI as long as the hubs are locked. Even if you're moving, you should be able to shift smoothly between 2 and 4 wheel. If there is grinding there (while moving) then it points to mismatched gears or tires.
So the donor truck (87 3/4ton) had a 3.73 front, and a 4.10 rear.
