91 Suburban fuel setup carb
ChronicalCP
Vancouver
Hey everyone new to the site but everyone on here seems to be way easier to deal with compared to other online sites. A little insight on my rig and the questions I’m about to ask. I bought a 91 half ton suburban in the winter with a blown motor (not in the truck when I bought it) for 500$. Has a lift and came with a bunch of pretty useless tires and rims but I’ve always wanted a suburban. After getting a little deeper into this project found that all the TBI wires were either burnt hacked or bare and exposed. So this would be the start of switching over to a carb setup. Ended up mounting a early 80s 350 into the truck that I was using for something else set up to run a carb. My main issue at this current moment in time is I’m a little foggy on my fuel setup and how to run it. I know I either can run the in tank with a fuel regulator or mechanical fuel pump and either remove the in tank or rig up a hose to the bottom of the pump and away we go.
Before I get way ahead of myself I would like to know which way I should go. I have a Holley 12-804 fuel pressure regulator and I have a new carter mechanical fuel pump the style with the three attachments as I’ve read that this year would need as it has a vent for the tank and the inlet and outlet. So I’m open to going either way on fuel setups. I’ve tracked all the fuel lines so after I decide what way to go it should be setup then trouble shoot any issues out. I have the feed line and the slightly smaller return but I’m very confused on the vent line. I see that it runs from tank top all the way to the front of the truck then across from passengers side to drivers side where it seems to go to a carbon canister right behind the headlights but this is what confuses me the most shouldn’t it complete a full circuit to work correctly or is this semi useless? I’m not worried about emissions as this truck will be a weekend warrior and will not need to go and try and pass to get weekend permits. Any help and direction would be great
A few people here just leave the stock fuel pump in the tank. A old style mechanical fuel pump off the side of the block will suck through the non functioning electric fuel pump.
Normally this goes to a vacuum port on the TBI setup. Just leave it going to the canister.
Awesome thanks! ill just run my fuel lines to the mechanical style and not worry about the vent line. Im guessing ill need to remove power from my intank so it is not powering on.
a good idea indeed!
you'll be running gas through the carb like a lawn sprinkler if you don't :haha:
a fuel pressure reg wouldn't hurt - get the pressure exactly where you need it.
oh, and Welcome to the best GM 4x4 site on the planet!
