91 Suburban V2500 - Tow/Weekend Rig - Build Thread
I need to triple check, but my painter did his absolute best to encapsulate it from both sides.
So, I think it's painted as best as it can be. If factory paint lasted 34 yrs, this round should do ok.
Just trying to search any other "causes" of this rot, and haven't found anything on CK5.
If it's painted it's good but if you put screws to attach the piece, you break the seal in the whole so put a waterproof sealer or silicone in the whole before putting the screw you eliminate the water intrusion
That was my thought. Thanks.
Core support paint needed a refresh. Rest of the truck was looking too sharp.
Painted core support, headlight buckets, headlight rings.
Reassembled. Ordered new turns, grill mounting parts, and side marker lenses.
Trying to put this thing together without too many upgrades. Easy enough to come back and do LED and headlight upgrades after it’s reassembled.
Touched up cowl paint area last night, reassembling cowl tonight.
Then onto doors. Seals, power window parts, clean lock parts, etc.
Finished rebuilding and reassembling driver doors.
Never doing vent window seals again. They had some paint on them, but really, should have left rhem
Needed to turn the truck around in the garage, and decided to take a much needed test drive. Good reminder that this thing is a runner.
Hasn’t really been driven in 4 months.
I rebuilt one pair, the next truck I went with a pair of brand new wing window assemblies.
The seals that I bought were pretty nice. But the fit/finish once installed, and fitment into my door wasn’t great.
I’m going to try and heat them and adjust better when the weather warms up.
Ha. Struggling to upload from latest iPhone interface.
Doesn’t let me upload reduced file size anymore, and all my
Photos are too big.
Used safari. Safari sucks.
Used Route La Custom precut side trim. I give them about an 8/10. They fit ok. Front doors need to be trimmed.
But, that basically marks the end of this reassembly.
Yes, always stuff to work on, but truck is basically back together!!
Did they have the correct 89-91 trim?
Yes
Side trim for 89-91 burb is 88+ truck style with different cuts, I think. Either way, matched old. And shipped flat. The roll from LMC would have sucked.
Front bumper strip is unobtainable as is rear corners. Plastic is ok,
Trying to figure out a way to just replace the chrome strip on each.
Amazon stick on chrome strip used on tailgate. Looks factory.
