96 Dyna Basket Case Build
Honestly, can't really tell you. I did the build, but we had to use a thundermax ecm that the customer wanted. The initial download apparently wasn't right, so it wasn't rumning right when I did the initial test ride. Plus, break-in period, so I didn't get on it much. I believe that after consulting with thundermax, our dyno guy got it lined out. It was supposed to come back for final runs after the break-in, but I don't know that I've seen it again.
Got the forks and front brake calipers mocked up. Trans and frame cleaned up and hopefully setting the 80” engine in the frame tonight. I’m resisting the urge to throw a cam and gasket set in it for a little more pull. A drop in ev27 Andrews cam work really well in the 80” stockers. Maybe if something leaks it will give me an excuse.
