96 Vortech 350 block and heads. Std Bore block. factorty roller cam block, SCAT cro-mo crank, SCAT cro mo H beam rods, Forged flat top pistons. 10.38:1 compression ratio. 96 vortec heads, fully ported and polished, screw in studs, 375# "yellow" L92 valve springs, machined valve guides, capable of .575 lift cam. cro mo push rods, roller rockers.
doesn't come with the intake, or distributor. but all the serp belt front accessory brackets are staying.
Helping a friend out on this. Let me know if your interested.
$1200.00 located in Reno Nevada, probably can arrange a ride at the correct times for a fee.
