crashandburn
So I picked up a clean 98 Blazer for $500. The motor was breathing its death groan. I put a motor in it, and it runs good, but it won go into 2wd. When I bought it, the vacuum actuator under the battery was disconnected, and that is obviously why.
When I hit the 2hi button, the 2hi light flashes a few times, then just stays solid on 4hi. I tried it in neutral and I tried backing up and rolling forward. When I hit the 4lo button, nothing happens at all.
Any ideas?
I brought I down to the parts shop and scanned it. It says the transfer case is not responding. I don't know if that helps. Sounds electronic.
Any ideas?
