You don't know if it was a dude
Bahahahha! Did he not look under the rig at all? Kids.
In the past I’ve always just set the toe myself with a tape measure and a straight edge. Really don’t know what I was thinking taking to them.This is why I will always just do my own. I tried to convince my buddy to do his own and he is convinced he cant do it. you need the machine hooked up to all four wheels and all that jaz... just to set toe.
Should have went this route.Yeah, it's a pain in the ass to do it right.
Jack up the axle and put it on stands. Check the axle with an angle finder, digital is my favorite. Zero it if you can with shims otherwise just take the number as your zero. Then start working on the camber. Camber shims behind the spindle is the only hard part. (setting caster is 2nd)
Toe is so easy with two people, two 4' straight edges (levels maybe) and a tape measure.
When you are done, it will be better than any work you would have paid for.
When I gained my composure after hearing him say that, I asked for the manager. The manager did it himself. And ultimately all he did was set the toe.Question is did the shop charge you for it?
That's funny.When I gained my composure after hearing him say that, I asked for the manager. The manager did it himself. And ultimately all he did was set the toe.
Jeep folk are good for repeat business.He's been dinking with the steering and suspension so much he's paid me 4 times to set the toe.
That’s all I ever adjust. Camber plates have always seemed like a PITA....And ultimately all he did was set the toe.
Leaving this early, you’ll still get to Amarillo by morning.
That’s like, dark
Ok GeorgeLeaving this early, you’ll still get to Amarillo by morning.
David
You drove it again? Thought you said you were going to ship it last year?
Yep! Something must be wrong with me.The journey is part of the journey
I want to do shorter trips near home. I'm afraid I have a ujoint problem but it might be cured now? To many variables and a 7 hour trip isn't sounding good.You’ve got to sometimes tell yourself “ screw it, and just do it!”
You built it, so you know you can wrench on it. Fill it full of tools and spare parts and point it the direction you want to go.
This is what I’ve told myself the last 3 years. Here I am again.
