Ah, well with that added info I’d say go with BentMarker’s plan.That’s after only 2500 miles of on road use. This is the second time for me to drop the pan in the last 3 months. It quit pulling before and I change the filter and all seemed good. But now It’s got a shutter it does between 3 and 4 at low rpm. So I dropped the pan just to check. The pics are what I found.
Fill it with Type F 90w might live a smidge longer.
Yep, It's not Moab that I'm worried about. I think street tires would rock it at that place. Its the local trails. Loose rock and dirt is where the IROKS really amazed me. I'll just have to see with these.I don’t think you’ll notice any less traction with the new rubber in Moab
changed the fluid and filter and all fine so far. No more shutter. Shifting well. Have had one full weekend of hard wheeling, towed a couple of vehicles, and coming up on 2,000 miles since the change. Asked several transmission shops about it, all have said there's defiantly wear, but don't fix what ain't broke. So I'm still rolling with it.So what happened with the trans?
Hey ChadBradchanged the fluid and filter and all fine so far. No more shutter. Shifting well. Have had one full weekend of hard wheeling, towed a couple of vehicles, and coming up on 2,000 miles since the change. Asked several transmission shops about it, all have said there's defiantly wear, but don't fix what ain't broke. So I'm still rolling with it.
Yes Bent! As long as the shifter has the bicycle lever hand throttle.Hey ChadBrad
want me to bring a spare 465?
Done!Yes Bent! As long as the shifter has the bicycle lever hand throttle.![]()
Dang that thing looks good! I was just recently thinking that I might need a newer Tahoe or burban with a big block or 6.5TD to build a wheeling rig I can beat on more. I just don't think I could ever let my K5 get an significant body damage.Finally, new rubber!! Cooper Discoverers STT pros, size 37-12.50-17. Sad to say that this is the first set of brand new tires that I’ve put on the Tahoe since I put it together. Went this route hoping for a little better road wear vs. the IROKS. Hoping I didn’t sacrifice much of the off-road ability. Time will tell.
Looking really good. I think you picked right on the tires.Finally, new rubber!! Cooper Discoverers STT pros, size 37-12.50-17. Sad to say that this is the first set of brand new tires that I’ve put on the Tahoe since I put it together. Went this route hoping for a little better road wear vs. the IROKS. Hoping I didn’t sacrifice much of the off-road ability. Time will tell.
