His name is Dean and says Fock Mooooo!!!!
Are you talking about the moo cow, or you?
And why does it look like your cow has been huffing silver spray paint? You guys bored up there already? Ya know, winter just started.
Glad to see this thing is still coming along. Looks great!
SuperDave, great for ya to stop by.
Are you in Cali, or Seatlle? Hard to tell from the FB pics.
[emoji106] [emoji106] [emoji106]
Made a little progress. Too much crap in normal life kinda keeping me down from long garage times. Just can't get in to it.
I did weld up the rear tube bumper and moved on to another project, I should have done a long time ago. (forgot to take pics of bumper weldup) Imagine a tube bumper welded up...
Way back in the beginning, the smart people had a little discussion about hard mounting the tub to the frame and cage. As you can see, I've pretty much been doing that, but never really got around to doing the actual body mounts. Before I can really go any farther on the rear bumper, I need to get all of the body mounts finalized.
So I worked on a way to replicate the originals, but this time in all metal. It looks like it will work throughout, with a couple tweaks along the way.
What do you guys think, as it looks like I'm the first little piglet to try this?......or get talked into this..
Started with getting the engine cage in again. This gives me 2.5 inches for my body mounts on each side for the #1 mount.
Started by making four plates. Two with 1.75 holes and two with 1/2' holes.
and welded caps to the ends. These will get a 1/2 bolt hole.
and some stacked washers welded together.
Drilled some holes for a couple plug welds. I needed to down size the tube from 1.75 down to 1.5. This gave me the opportunity to use a 1.25 tube to go through the actual body mount bracket attached to the frame.
Cut the tube down to 2.25 and slid in the 1.5 tube.
Then I welded the 1.25 tube (3/4" tall) to the plate with the 1/2" hole. This slips through the body mount bracket hole and into the upper mount. I figure it should give it some stability from side to side racking.
It slips together something like this.
And mounts in here like this..
That's it. Only 8 more to go, if I get the stamp of approval.
