Ned Kelly
Check these Army Lube Charts for an idea on how a 6x6 drivetrain is setup using one transfer case:
http://g503.com/forums/viewtopic.php?f=82&t=212846
There is a WW2 Dodge WC63 6x6 lube chart on the net, and shows you the one transfer case to power all three axles. The NP200 transfer case found on Dodge M37 or Kaiser M715 work well for a 6x6 conversion as they have dual rear outputs. One output is used for the rear axle, and the other output has parking brake on it. You can put a driveshaft on both of the outputs.
There is a guy on one of the Dodge forums that did a M37 into a 6x6. He is also on the Steel Soldiers Forum as user name 'M376x6'
http://www.steelsoldiers.com/showthread.php?31071-M37-Driveability&p=330942&viewfull=1#post330942
There are some images of it but I can't find them.
