crawlink5
78 Blazer. Got the A/C going today. Needed to put electric fan on because flex fan was not moving air. Used a 98 Mercury Grand Marquis 2 speed fan.
have recently removed fender and evap box and cleaned it out, cleaned coils, and resealed box putting it back on. It was not that bad.
Motor is about 5 yrs old but with just a few hours run time for heating.
Cold air is coming out. The air is blowing hardest in the far driver side then as going to pass side it gets less. On max setting and high switch no air is coming out of heater box or at windshield. Its just not blowing hard especially on pass side. It SOUNDS like it is blowing hard but it is not.
Cold or heat baffle moves freely. High low switch works correctly and is new. motor relay is new. I did not change the resistor coil things in the evap housing. Showing 12.5 volts in factory guage, have 140 amp alt and two batteries.
Is there a super duty jet-rated blower motor I can get from somewhere?
Any ideas on what to check next?is there a connection somewhere that could be giving resistance because its old?
