I am in the process of replacing all of my A/C components on my 1985 K5 that had factory air (C60 RPO). I have found all the part required except on the fill lines that do not look like my original line.
Can someone tell me what the "Bulb" is on the right side ?
This is the side that connects into the condenser. As you can see I have the line still attached to the Evaporator to show the relationship.
All the fill lines I have located have the connections and the charge tip. None that I have found have this "bulb".
Thanks !
Thanks !
