You are still in the ballpark as to weight. Only 3.7 oz over the original R12 charge. I suspect that the new evaporator holds more than stock.
With home ACs, you look for a 20 degree differential. In other words, with 90 degree air going in, you want 70 degree air coming out.
Note: That is the temp of the air going into the evaporator, not the outside air.
Auto ACs can run a higher differential.
I would take it around the block to see what the inside temps do, since an AC will usually do better when the airflow is increased over the condenser.
You will probably need a small amount more gas. As long as the high side pressure stays sane, and you do not get any frost on the output side of the evaporator you should be fine.
The main two dangers with gassing are too much high side pressure which can blow hoses or damage the compressor. Plus liquid freon getting to the compressor, which will destroy it really quick.
If liquid is getting out of the evaporator, you will see frost on the line going to the compressor. Heavy sweating is OK, and you should see some when the air in the cab starts to cool off.
