while i think the hexagon is likely not the optimal form, i think there's ways you can work with it. i have an idea that might work (which needs further development). naturally, the hexagon shape when pressed down upon from above is going to want to squish downward. so, if you had a bar in tension between those two points, you should effectively solve that problem - as the hexagon squishes downward, the lower bends will want to move outward, but if you have a bar connecting those two points, it will be in tension and it will prevent those from moving, making the form very rigid again.
this is easy to do on the b - pillar hoop, as you can just run a bar between those two points and have it be a great spot to mount your seatbelts to. with the rear hoop, however, you likely wont want to do that because it will get in the way of cargo. since i assume you'll run a tube along the bed rail between those two hoops, however, you can do another shoulder-height bar behind the rear seat and gusset it out. this should make the form strong enough, i think.
another less desirable option would be to put a rib gusset on the inside of those bends which would strengthen them up pretty well.
bending those back out will be rediculously difficult, imo, particularly if you want it to look good.
(had to use a porta power to spread the feet 2"!) Plus, bending and unbending metal= weak material at bend!
My bad! Yeah, I'd rather replace them if it came to that though, each bend weakens it a bit more.
) Gussets, yeah, I wanna gusset the snot outta it, we'll see how many I can do before I get told it's too many!
How much lift/what size tires are you running? I'm planning to put a V type brace on the sides, I just didn't draw it because it looked very confusing on my pic. I am planning to run the horizontal bar at the bottom of the rear most hoop as part of a spare tire carrier (I lay my spare down in the rear cargo area and want to build a holder for it that is cage mounted).
so cargo space is important to me.
