A few questions about restoration.
jyreene
Oceanside
First time poster, long time reader. Here is a little vehicle info for you:
86 GMC Jimmy with Stroked engine from a 78 Blazer. Spring over lift, not sure the exact height of the lift. 32" tires. Old Tan paint and interior which the wife and I will be re-doing with a Superman theme, slowly over the next few years. Now to the questions. Keep in mind it's been 13 years since I've actually done any mechanic work so I'm a bit rusty in areas. Oh and links to threads with the answers are fine. I've done some decent searching but not found specific answers yet.
1. Wiring. The wiring is atrocious. The PO, or his son, added an aftermarket stereo and amp as well as a tachometer (which doesn't work and I don't plan on keeping in that spot). After removing the stereo because it was causing a battery drain I noticed the hatchet job and general mess under the dash that is the wiring. I want to re-wire the entire vehicle mainly because of the mess that is the current wiring because of the above mentioned add-ons. I have very limited experience with wiring and in fact that was the ACE cert test I could never pass. I don't know that I want to re-wire the vehicle myself, with the wife's help. Does anyone know what the cost would be to have someone re-wire it? I'd be willing to do it but this is also my daily driver right now so anything that would take more than a few days to a week of working on it after I get off of work makes that a shaky proposition at best. Any suggestions or ideas?
2. Gauges/Dash. In all this I plan on replacing the dash, since it has a few large cracks running from the windshield to the front of the dash, and the gauges and bezel too. To go with the theme we are wanting the dash will be black, the bezel will be powder coated red, the gauges will be blue numbers and needles, and the rings around the gauges will be yellow. With that info any parts leads and do-it-myself tips would be greatly appreciated.
3. Body work. the body is pretty good overall. There is really only one big issue and that is the PO installed an aftermarket external tire rack that would swing open to allow the rear to open up. This was a pretty poor installation job as the the weight of the tire over the years apparently started to rub the mounting holes to an even larger size. I have since taken off the spare tire rack and purchased an internal original mount that I will modify to accommodate the larger tire. For repairing the holes for the long term would it make more sense to take it to a body shop and have them weld in some patches or just use some good quality body filler/bondo? Included in this are the various holes from the emblems that have been removed.
4. Painting. The outside and any metal inside will be blue. The shell will be red, it is in good shape and only recently got a nasty scrape that took of the paint, since sprayed over to prevent further peeling. Chrome Trim pieces will be powdered or chromed yellow. And the hood will be receiving a Superman emblem that the wife will paint. Interior will be all black carpet and panels. Now the questions, any prep work do-it-ourselves-in-our-garage tips? Any tips for painting the shell? Tips on removing and re-using or buying new and painting the trim pieces? Interior tips (we plan on trying to salvage as many of the tan pieces and using the duplic-color vinyl paint kit or finding a parts Jimmy or Blazer that already had black interior)?
5. Seats. I'm kind of lost here. The seats we want will be red leather with yellow piping around them and in the pleats. The seats need to be re-done completely but I don't know if it would be cheaper to buy a set of seats and re-upholster them how we want. The foam is pretty worn out and the springs are probably in need of repair or replacing. The back seat is in much better condition and really only needs to be re-upholstered so this is primarily for the front seats. Any suggestions as to whether I should rebuild the current seats or go aftermarket? What about taking seats from a newer Jimmy/Blazer/Yukon...etc? How easy would that be especially with the difference between non motorized and motorized?
6. Center console, the current one is attached and the lid works. That's about all that can be said. It doesn't lock anymore and doesn't stay completely still. I plan on building my own but am unsure how to go about it. MDF, foam, and upholster. Make a mold and do a fiberglass one and paint. Buy aftermarket and go from there. Which would you do? The first two would be the most time consuming and a new experience but a lot of fun overall I imagine.
7. Carpet. The carpet is not only the wrong color from what we want but very worn and tired. I am stuck between wanting to take it out, clean things up, and just rhino line (or similar product) the floor pan (not sure how good a job this does of sound proofing but I did find a thread on how to do it just without an answer on sound proofing). Replacing the carpet and all sound/heat proofing with aftermarket pre-cut from a place like LMC or similar. Or replacing it with a vinyl "carpet" that you can also get from LMC and other similar places. Any ideas? Tips?
8. General/other. Any other general restoration tips? Customization tips? Parts sources? Donor sources? Thoughts on level of restoration, ground- up, frame off, and so on?
We won't be doing any real work until about 4 years from now due to an upcoming overseas move but I plan on reading up on, learning about, and slowly purchasing the necessary parts, equipment, and tools until we do start the work. I know this is way ahead of time but as you all know none of this stuff is every free or cheap when it comes to completely restoring things. Thanks in advance for all the help and thanks for all the great posts that are already on here.
Ty
No pic yet
It won't let me upload a pic of it yet since I haven't made 5 posts.
I'm doing a mild restoration on my Blazer. I want a good daily driver and occassional off road use. Yoy will find parts are hard to find and when you do find them the owner of the parts are proud of them. Rust is the big issue. My Blazer only has a couple of spots of rust, but one is an easy fix with a little patch and welding, but the tailgate.....It has internal rust. Looks like a new tailgate. Then the parts to make it right are over $300 for repops.
Oh yeah, welcome to the madness!
Keep posting, the five will come quick.
I just hit them.
That's kind of what I consider we are doing since I don't really think I would be reasonably capable of a frame off restoration and have it be a daily driver within a reasonable amount of time! The only rust on it are a few tiny spots where there is some bare metal. I sprayed those with some good military spray paint, not even close to the original color but who cares at this point, just to stop the rust from spreading. Parts, yeah. Thats a big one. Also why I'm thinking of enrolling in some local night tech school for interiors and just using my Jimmy as my project vehicle. Good luck with the tailgate.
The wiring isn't that bad overall. As for the interior it is not that hard to do. Some of the parts can be hard to find. Look at the frist part of my build it may help some. If I can give you any info that will help just ask.
As for a frame off its not hard it's just time consuming. Not for one that needs to be your daily driver with little down time.
Teck - One question. Where'd you get those rear panels in such great condition? Never mind. Changing that question to a quick down and dirty how you made them.
They are cut out of 1/4" plywood. Then I had a guy I know that does upholstery work cover them. I took him and old one to use as a pattern. He glued a thin layer of foam to the back of the vinyl then stitched the linens in them. then glued them to the wood panel. I could have done them but didn't have a way to sew the pattern in it and he made me a good deal
Nice. I will be saving this to show my wife when we get to it. By the way nice build. Want to do mine next....
So far it just needs a good dusting.:doah:
Darn it. So no free restoration for me. :thinking: How about if I build a rolling self deploying awning that will fit in a duffel bag that you can drive under during those wonderful rainstorms you get in TX? Anyways. I still love your truck. I just put my ideas (wife helped) for the restoration of my Jimmy down in a post (link in sig block). I do want to go fairly original with just the color touches being the difference. You're build gives me the inspiration to do all the little things like nuts and bolts over time also and really give this truck the love it deserves.
Superman, huh? Well, everyone has their own thing. :D
You have quite the list going on.
Wiring isn't something to be rushed. Painless makes a good harness for these trucks but it will take time to get it right. So, plan on that.
Seats. Have a look at this thread http://coloradok5.com/forums/showthread.php?t=267326
See if that is something you want to consider. This will take care of your center console too. They are 100x more comfortable than the factory seats. Plus, in your case, you may be able to find custom material in the right patterns or "made to order" because they are from a newer vehicle that is pretty popular for customization.
It's kind of both my wife's and my thing. I was going to paint it green but she did a quick drawing and I liked it.
The lists never end though do they?
Wiring does seem like I would really need to take my time. One thing I'm considering is going through DIY4 for his custom dash so I would also have to learn some tricks of wiring something new. I'm sure you guys will be able to help when that time comes.
I do like those seats. I added a question to that thread but wouldn't it be a good idea to secure those mounts with a few welds?
Exterior trim pieces and rubber question.
I got to thinking the other day about the trim pieces. When it comes to finally assembly and the small details I realized that I am lacking some info. I know there isn't a true color chroming process so I was curious if anyone has had experiences with the color spraying of chrome trim pieces. I know it adds, very slightly, to the original size of a chrome piece so fitting it back on could be a little more time consuming.
Would getting them powder coated allow a similar shiny look? I've never had anything powdered coated so I'm not sure if that is possible. I basically am trying to figure out if "chrome" yellow trim pieces is possible or if I'm going to have to figure something else out for the build my wife and I want to do.
@496truck, thanks for the seat build thread. Those look real nice. Now to find a way to mimic your build with a 3rd row 'burb seat.
What chrome pieces in particular? Are we talking plastic chromed parts or metal or what?
Like the pieces around the wheel wells, around the grill, around the windows, the side lights, the mirrors, and the bumpers.
A lot of that is stainless or aluminum, not really chrome. The plastic trim around the side lights is chrome plated.
I know with the plastic you would want the chrome plating removed for best results. Some sandpaper would do the trick if you can't get them blasted with a media of sorts (glass beads, walnut shells, etc).
The stainless trim around the wheel openings is in a vulnerable spot. The main reason why it's not painted in the first place, it will get hit with rocks and sand and it will chip off. Even powdercoating won't stand up to the abuse. You could sand the surface and use a spray bomb on them. Just plan on doing that again and again over time. You could also look into a place called Durabak. They have a bedliner material that comes in colors and may hold up a bit better for that location. The trim around the grill is stainless also and vulnurable to chips as well.
The aluminum window frame around the side windows, I bet you could get away with sanding, primer, and paint. I would remove them from the fiberglass top for best results (no tape lines).
