A Few Serp Swap Questions
Discussion in 'The Garage' started by Drey, May 6, 2007.
  1. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Can I just take pulley off a serp powersteering that was non hyrdo boost and put it on a hydro boost? Same with alternator pulleys
    The serpintine stuff is coming off a 89 K5...Mikeysd_05s Pumpkin to be specific and going on my 83 K10. Although its only going onto a 6.2
    Everything is coming off the 89 350 and going onto a 73 400.
    Which brings me to my next question. When I go to get a water pump do I just get one for a 89 K5 with a 350, both are SBCs but will it just bolt up. Or do I need to find special one for that 400?
    Latly Ive been thinking about the feasability of doing the serp swap right now at this point and time and am thinking about just keeping the VBelts for now and peiceing together the serp setup later.
  2. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,181
    3
    Hollywierd, CA
    I know you can with the alts and pretty sure you can on the power steering.
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Power steering *should* bolt up as well. As long as it's a ham can style pump I think it'll work. What year was the original 6.2 again?
    I have no clue on the water pump...I still have to look at a v-belt setup to see if it's reverse rotation like you said.
    Sorry, I'd let you test fit mine but it went with that SBC that I sold to Terry for a customer's truck. :doah:
    You still owe me $100. :p:
  4. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I know I know Mikey youll get your money...
    that 6.2 is the 83 original
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    you'll never find a listing for a 400 for a serp. belt set up GM quit offering them before serps came out.
    The serp. set up will be reverse rotation so any late 80's early 90's WP will work.
    also I'm kinda confused as you listed a 350, 400 and a 6.2.... whats getting which,LOL
  6. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I got all the serp parts off a 89 - 350
    Im using the Alt and Hydroboost that came on the 83 - 6.2
    Its going on a 73 - 400
  7. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    and the joy of GM, it'll all fit on the 400.
  8. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    sweet thanks guys
