A.I.R system?? -have loss of power… code 43 for knock, and 44 for lean condition????
If the fuel pressure is low, it will have been adding fuel from the stock table. Disconnecting the battery will put it back. I think the lean condition code indicates that it can't trim any further. A misfire typically reads as rich.
You could try taking the A.I.R. tubes off the manifolds and plugging those holes as a test. IIRC, it's a weird pipe thread and not a standard bolt thread.
Air tubes are attached but the inlet from the pump is capped off at this time - exhaust SMELLS better but truck is running worse than ever currently
You can unscrew the check valves and use an iron pipe cap to seal off.
1st pull the hoses off check valve and see if any exhuast is coming out off the check valve it is not supposed to.
Take a hammer handle and give the egr top a light rap, sometimes helps the pintle seal if carbon is holding it open.
Didn't say if IAC passages was clean ? Did check the TBI base gasket ?
Yeah I’m going to try tapping on EGR. I’ve tried disconnecting and capping vacuum line- doesn’t run any different
EGR appears to open with a vacuum pump and hold vacuum
As for as I can tell the gaskets on the throttle body are good- nothing inside or outside sticking out and no smoke from the smoke machine leaked out there
Soooo out of desperation to get home for the weekend and bring back axle parts of my daily driver to fix…
The blazer was driven 170 miles in its current state.
Started out not horrible- got worse.
Initially taking off from a stop was underpowered but manageable- carefully feed the skinny pedal and slip the clutch.
Once cruising at Hwy speeds it was ok, but Check engine lights on and off throughout the freeway ride. Steady on the gas pedal, but could feel a percentage of the power disappear and then Come back and then disappear again- not always in time with the check engine light going on and off. I think this may have been the knock sensor retarding timing
Someone cut me off in traffic and the engine stalled when I came off the gas and stabbed the clutch.
Once stopped, lots of cranking to get it running again.
Made it home- it stalled as soon as I pulled up to my garage behind my apartment.
Let it cool off and had to run to catch a date- it runs absolutely horrible now.
Bucking- barely idling- chuffing sound coming from exhaust, no power, not sure how many cylinders are firing, shaking, almost impossible to get it started from a stop. Lots of use of my non synchro low gear - lots of grinding trying to force it in gear to avoid stalling.
I felt like a stressed out octopus trying to parallel park while it coughed and sputtered and stalled
Only code that stuck in the memory this time is 44 - that’s knock sensor right??
if you have an hei distributor, drop that in and see if it improves. The TBI dist are crap
You mean “cap in coil” type? I thought the TBI ignitions WERE considered HEI?? I have a special spark plug looking tool with An aligator clip on it… it’s for HEI ignition systems-has some kind of resistance built in, and a cage around the electrode.
-take plug wire off spark plug
-plug this thing in
-ground the aligator clip
-start motor
- if a spark jumps the gap between electrode and outer cage (1/2inch)
Supposedly that means the coil/cap/rotor,plug wire are all functioning correctly.
This thing was marketed as the HEI version, and I’ve always used it with the TBI stuff.
-quickly eliminates all the upstream components, and helped me find a faulty plug wire one time -was out of spec but still occasionally allowing spark plug to fire
Couple thousand miles ago that was 14psi
This is a different gauge than what I used last, but according to this one, I’m not building ANY fuel pressure with the key on before starting, and then while the engine tries to idle it’s between 5-6 psi
Going to see if any of my spare throttle bodies have usable fuel pressure regs on them… (I have a handful of new ones but the box is missing!!)
if so I’m taking the fuel pod out of the blazer to see if it’s shot.
yeah I am not thinking spark quality, and thinking timing. These distributors have a high failure rate, shaft bushing, pick up coil. etc.
That is very low FP, where are you tapping into the fuel system ? I use to plumb my gauge in place of the fuel filter.
Let’s see… there’s a one inch throttle body spacer… wether or not it does anything for torque is a fantasy argument, but it creates room for a extension between the throttle body and fuel supply line- that extension piece is tapped 1/8npt and I used to have a permanent fuel pressure gauge mounted there- recently was plugged. Pulled the plug and stuck a shrader valve in there yesterday- pain in ass getting a hose in there because the coil, throttle cable are in the way, but it’s possible!
Remnants from trying to pull more power out of a TBI, but I used to have that one inch spacer, an injector pod spacer, adjustable fuel pressure regulator on the injector pod, bored out throttle body with the air horns milled off, removed the sheet metal collar/spacer from between the air cleaner and throttle body -air cleaner sits directly on top now… and a tall air filter lid from an older truck so I can use the 5 inch tall filter elements. It all clears the hood barely
Not saying there's nothing else going on, but you need to prove that gauge is bad or fix the fuel pressure issue. It should be 2x that, so no wonder it's logging a lean code. Possibly all of the lean misfire is tickling the knock sensors.
Do these have a soft return line you can pinch?
