A long shot... Marlin Crawler rock sliders??
Look interesting, and up to 80" length available
Wonder how much fitting to fit our frames...
No, the Marlin ones have the brace tubes at a 90* angle to the main pipe
And half the price
Just for S&G, the 80" might fit my k10, about 6-8" to each tire, didn't look too close at where the leaf spring mounts might interfere with the slider mounting
I presume some field engineering would be necessary
Price on shipping: $35
I ran trail gear sliders for a little while. Different lengths are available.
If there's one thing I wish was different on my rig, that would be a HUGE PITA to change now, are my sliders.
I wish I took the plunge and cut my rockers out, giving myself just that little bit more ground clearance. With the cage tied in to them, it would be a major undertaking to change now.
Just a thought to anyone who is already using their truck for mostly offroad anyway.
Before you order, ask them if they will send out a set with no mounts welded on. Then you weld on whatever you need to fit your K truck. Less work for them, less work for you. Maybe they will even knock some $$ off
Too late! I was under the assumption the bar is separate from the kickers. We’ll see Monday maybe
