) I'll know how to fix her up real nice.
Hadn't thought of that. Did you put a windshield in for fitment before/during welding, or did you just do some real tight measuring?I repaired one that was damaged. Had to cut the bad section out and weld in a new piece. I also grafted a '74 windshield frame onto my '81 Jimmy when I did the full convertable conversion. I used some 3/4" thin wall tubing as spigots (and backing for welding) The A pillar is hollow as I'm sure you already know. Spigoting the section with small tubing keeps things aligned, and prevent blowing holes in the welded area
Rene
