aaah wheres N located on a th-350 tranny?
84gmcjimmy
1 ton status
B.C. CANADA
I'm trying to get the k5 in nuetral so I can roll it back with the rear driveshaft in. I have all the shifter stuff out, so I have to do it from the linkage beside the engine, I need to know how many clicks down N or even R is good I guess. I cant find the little plastic piece that says that so Im out of luck.
Anyone care to help me/ /forums/images/graemlins/waytogo.gif
Pretty sure on a 350 it's the third notch from one side and fourth from the other. P - R - N - D - 2 - 1
Just try it out...whenever your truck moves when you push it, you're in neutral.
I tried pushing it on a few gears, but it seemed they all moved. But when I looked at the brake part, it was like curling up or something. It's hard to explain
I will try to get N now, thanks!
I think I found N, and I took both driveshafts out because i cant shift the x-case.
hopefully it'll skid and move /forums/images/graemlins/woot.gif
once you move it and the weather changes you'll never get back to it. /forums/images/graemlins/histerical.gif
Cause you'll leave it apart all winter and forget how it goes back together. /forums/images/graemlins/rotfl.gif
thats why I have you guys to tell me where everything goes /forums/images/graemlins/rotfl.gif
I took lots of pictures so I would remember. The only thing I am worried about is wiring, I kind of forget what all the wires do /forums/images/graemlins/crazy.gif
doesnt matter what gear its in, the auto trans is based on fluid couplings, and without the engine running, everything except park is neutral.
[ QUOTE ]
[/ QUOTE ]
oh okay. Thanks! /forums/images/graemlins/woot.gif
