Rant on.
The new blazer is killing me.
So far.......
Radiator
Thermostat and housing
Radiator hoses
Temp gauge
Finally figured out the heating issue was the temp sensor.
Replaced the battery because it would not crank when temps are low.
Replaced started because the bendix would not always engage.
Today the left front brake quit working. Fluid everywhere. Got it to a friends shop by work. Banjo bolt was loose.???? When we pulled the wheel to make bleeding easier, noticed the hub moved 1/4 inch up and down. I left.
He calls to tell me the keeper rings were loose and had cross threaded. Bearings were shot. Probably was the ticking noise that started on my way to work.
He shows up to pick me up. I could hear the ticking was worse. Flex plate is cracked. Made it home, but it is loud now.
And a noise is coming from the left rear brake now.
What heck is up with it??????
Rant off.
So far.......
Radiator
Radiator hoses
Temp gauge
Rant off.
..the owner wasn't pleased to get a 75 dollar bill to replace a fuse,but it did take all day to spot the problem..my friend did not want him to pay for the module,but he did anyway,said it was just as well it was replaced,as they do fail often with no warning..
