Abandoning Project: LOTS of items
blasphemous
Louisville, KY
$1400 - dana 60 SRW front axle; 4.56 gears w/ open carrier; new bearings, seals, rotors, calipers and brakes pads w/ lockouts and new wheel joints
$600 - 14b FF SRW rear axle; 3.73 gears w/ welded spiders; new bearings, seals, rotors, K20 chevy calipers, brackets and brake pads
$250 - 4.56 thick gears and carrier
$600 - Ground Hawg tires (40x17x16.5, 50%) on 16.5x12 steel wheels
$100 - SM465 transmission - 10 spline
$150 - NP205 transfer case (w/ adapter and coupler) - 10 spline
$100 - Hydro bellhousing w/ fork, boot and throwout
$100ea - High steer/X-over arms for D60
$120 - hydro-assist parts from surplus center
$150 - 3/4" heim joints (3 LH & 3 RH w/ jam nuts), x4 3/4" bolts 3" long w/ 2 washers and 1 nut each, 4 threaded inserts for 1" ID tubing (2LH & 2RH) and 4x misalignment spacers
$50ea - 2 pieces of 4' long, 1.5"OD/1"ID DOM tubing
$75 - factory 52" springs w/ Energy Suspension bushings and painted
$300ea - 2 sets of 56" springs w/ 4" lift - one set new, one set used to mock up
$75 - DIY4X gen 1 shackle flip modified to fit gen 2 trucks
SOLD $50 - DIY4X HD front shackle hangar kit (part# 00380)
SOLD $10ea - 2 sets of 6" shackles, 3/8" thick
$75 - 1410 yoke for 14bFF (#1749?)
SOLD $75 - 1410 yoke for rear output of NP205 (spicer #G-1095-1?)
$150 - NP205 SYE kit, NIP
$40 - Energy Suspension bushing set #3.2128G (new)
$20 - RuffStuff leaf spring mount, 2 sets
$50 - '85 K30 tie rod ends (all 4)
$100 - '86 K5 frame - modified
$50 - 305 Chevy engine from 86 K5
$50 - NP208 x-fer case from 86 K5
SOLD $100 - Stock 10b axles front and rear from 86 K5, 3.08 gears and open diffs, complete minus lockouts
$80 - ARP head studs for BB Olds (185-4001) NIB
$50 - ARP main stud kit for BBO (185-5401) NIB
$75 - Holley Street Dominator intake for BBO, needs cleaned up, but useable for a street car
$400 - set of Ga heads for BBO, new rebuild, never ran
$50 - G-body headers for Oldsmobile
$200 - Powermaster XS starter for Olds (95101) like new, only used 3 times; a lot of shelf life
$60 - New AC Delco alternator for Olds (fits 72 Cutlass) only ran twice, then removed
$20ea - 3 sets of lifters
$200 - Edelbrock 750 CFM carb (#1407) like new condition
$40 - SA Gear BBO timing set - 78213
$20 - Factory HEI dist - core unit
? - Olds cam R9625 (6332/633458)
$50 - Lunati Olds cam (#00083, 112, J2JP) 224/234 @ .050 duration, .496/.520 lift, 112 seperation
$50 - B&M Holeshot 2000rpm converter for BOP
$10 - Set of freeze out plugs for BBO
$20 - Mahle rod bearings (#BC-304J-STD)
$60 - Durabond cam bearings (O-6) for BBO
$20 - Factory 455 pistons/rods
$100 - New pistons, cast w/ 15cc chambers and .060
$100 - Moroso valve covers, tall, chrome
$100 - Olds 455 bare block, needs bored out, 1969?
$200 - Olds 455 nodular iron crank, needs turned
$40 - CE Drag Shocks - C2720 rears; 64-67 Cutlass, 71-78 Toronado and other GM products
$40 - CE Drag Shocks - C2700 rears; 64-81 Cutlass and many other cars
$40 - CE Drag Shocks - C2610 fronts; fits several vehicles
$50 - Bare B heads, need refurbished
I'm open to reasonable offers on everything here. Some things may or may not be priced correctly, so I'm open to suggestions as well. I have to get rid of the big stuff for sure. I REALLY don't want to ship the big items. If you can pick them up, I'll be more willing to work on the price. Shipping is not included on any of the items and they're for sale in more than place.
I'm also pretty busy most of the time, so I might not be able to get back to you ASAP, but I will reply as soon as I can. I'm in the process of taking pictures of everything, so please be patient. I'm abandoning this project because I now have a M35A2 on the way home and there's no room for this project anymore.
1 set of 6" shackles, 3/8" thick
How much shipped to 32506?
2nd in-line for the DIY HD front shackle hanger. Does it have the poly bushings and bolts?
What is "$40 - Energy Suspension bushing set #3.2128G (new)" for? Spring eyes?
Still possibly interested in the hydro assist parts and the Gen 1 shackle flip as well. Got pics?
Hot damn!
You're going bigtime, eh :eek1: ?!!
:bow: :bow: :bow:
ALL HAIL THE DEUCE!
:bow: :bow: :bow:
Would this still work a 1st gen? If so would you do a $100 shipped for it and the shackles to zip 29101?
May also be interested in this " $75 - 1410 yoke for 14bFF (#1749?)"
Hydro Assist Items: $100 +shipping (edited price)
/4" X 48" 1/4 NPTM X 1/4 NPTM 2750 PSI HYD HOSE
Item# 916-1448 $8.60in
$17.201.5X8X1 DA HYD CYL SWIVEL EYES
Item# 9-7258-8 $84.951 on
backorder
$84.951/4 NPTM x 1/4 NPTF 90 SWIVEL
Item# 9-1501-4-4 $1.95in
$7.80SAE 4M x 1/4 NPTF ADAPTER
Item# 9-6405-4-4 $2.19in
$4.38
One of the pieces of DOM if it is truly DOM. Shipped to 76513.
It is seamless DOM I purchased to use for a drag link and tie rod bar.
who's arms are these? pics?
I'm not sure, I'll have to get pictures and let you decide. I can't remember who the maker is.
Not without UN-modifying them, but could be done. Just have to cut off the steel I added on. Also, I have a rear 305 output yoke and 14bFF yoke both for 1410, I just forgot which one's which. They're both complete, never installed w/ hardware.
I found those bushings in a box I opened up. I'm not totally sure what they're for. The bag has never been opened. They're for a set of spring eyes and possibly shackles.
The front shackle hangar mounts are complete, hardware and poly bushings included. I took them out and painted them (black), but that's it.
I'm getting pictures for...
Ground Hawgs and wheels
Hydro-assist parts
DOM tubing
D60 x-over/high steer arms
DIY4X shackle flip
DIY4X front hangars
1410 yokes
Here's a picture of my actual deuce...
What make are these?
I won't ask for a shipping quote since all of this stuff will fit in a USPS $8.95 flat rate box.
Thanks,
Pete.
