? about a lift kit
aealliarmy
Newport News, Va
i just bought a 1988 chevy K-5 blazer and i want to put a 6" lift and 35x12.5 tires onto it. I was wondering if there was anything that i would need to do in order to put those on or if i am able to bolt them on?thanks for all help
aealliarmy said:
i just bought a 1988 chevy K-5 blazer and i want to put a 6" lift and 35x12.5 tires onto it. I was wonderingif there was anything that i would need to do in order to put those on or if i am able to bolt them on?thanks for all help
You'll need to regear or do a axle swap. Personally I'd do a 3/4 axle swap. Stock axle gears + large tires = burnt out auto tranny.
You could just bolt those things on, it's a pretty easy deal .. but like Z3PR said, gearing can make all the difference.
What do you plan to do with the K5? What type of wheeling, how much ... future plans ... daily driver?
If I may make a suggestion... hold off doing anything on it right now. I know it's tempting to jump right in with both feet.. but I would suggest hanging around the forums here.. and reading on the different swaps etc that people here are doing. Depending on your future plans.. you may save yourself a lot of time and money. I'd say give it a couple to a few months, and then see if your plans have changed. Listening to others experience with different set ups (perhaps ones you had planned) could help guide you towards something better, and you'll benefit from not having to spend the money & time only to find out it has it's short commings. If, in the end you still want the first plans, then you've not really lost anything... but if you do change your mind.. the savings can be 10 fold.
Good advice.
i plan to keep it a daily driver until about december of this year . and to take it mainly in the mud and a few trails. and mainly on the weekends that i have off work.
__________________
this is a great idea! coming from someone who is doing that now, its nice to know the do's and don'ts before you do something. I love thi site!!:D
im running stock drivetrain right now and 36in iroks. no tranny probs..
It can be a basic bolt on. Depending on how you plan to use the rig changes how much work is needed to do it. At the least longer break lines, and lower the t-case.
Don't fall into the 1 ton or go home bull chit, it is not really a "must have".
lol this truck has been running this setup for atleast 10 years.
maby the previous owner did regear :confused:
