ABS Conversion
Rolled
Anchorage, Alaska
Any info out there on adding ABS to my 82 K20?
I have a 1991 K5 with ABS (I think) and am wondering if it is worth pulling (before it goes to the crusher) and putting in my k20?
Any advice? I am not really sure how the system even works so I don't know, yet, what parts to pull.
Its a seperate system from the motor ECM, right?
I'm pulling the pedal assembly for an auto conversion and thought I may want to add the ABS if its not a hassle...
ACK! NO! BAD! :rolleyes:
Seriously, it's a pretty miserable ABS. It's rear wheel only, and is famous for failing ... not that it does much. The only truck I ever had with it kept popping codes and it was easier to disconnect it and treat it like a normal system.
-- A
Yeah, I wouldn't want it. Even my S10 is popping codes, and it doesn't even have ABS! Figure that one out.:crazy:
