I'm replacing my r4 compressor, dryer, pf condensor, compressor hose. I will flush the evaporator and hard line.
What I found on utube shows to use pag150. Add 2oz to compressor, 2oz to evaporator, 1oz to condensor and 3oz to the accumulator. That's the clearest info I can find.
Turn compressor by hand to prevent hydrolock, make sure to lube all green orings, blue orifice. I've got the correct pressure switch. Suck it down, verify no leaks for 30 minutes, suck it 45 minutes longer to insure all moisture is out, and then recharge. I think I'm looking for 30 low and 200 high.
What have I missed, overlooked, got rwong, or need a heads up.
I'll be diving in to this as soon as it's cool enough to get a few hours in. Thanks y'all!
