It's been a long time since I've had to work on my own rig but my center AC vent on the dash board is frozen in the open position and my question is, can the vent be removed from the front of the dssh or do I need to remove the dash pan and remove the vent from the backside? Once the vent is out I will soak the vent and take it apart and clean and lube it properly then reinstall. I'm hoping I don't need to remove the dash pad as my gauge cluster is a mother to remove since I installed all the Autometer gauges years ago.
....but that's what they named them..
..now your limited to using adhesive or double faced tape to put the emblem on with,or buy a costly aftermarket replacement if one exists..
