I just did a serpentine swap onto my 1986 305 k10 and I had a question about wiring the AC. 1st question the harness in the picture the left side went to my AC on my old V belt set up and I cant remember where the right side goes to. The right side has 2 wires going into the plastic connector and has 12volt hot once the AC is on. The left side goes back to the switch on the dryer and does not get hot when I turn the AC on.
Also the harness that plugs onto the 89 compressor seems to have a resistor that jumps the 2 wires. My 86 plug does not have this, do I need to wire this plug instead of my old one?
