Advanced Adapter Slave cylinder set up
shock88
Electric Pole Dancer
CT
So I’m back trying to get my LS/nv4500/205 set up going again, My main issue is the length of the slave cylinder pushrod. Does anybody have a picture of this set up installed? I’m using the advanced adapter bellhousing, their cast clutch fork, and slave cylinder bracket. to a GM NV4500, and the factory square body clutch Hydraulics. I haven’t fully assembled it yet, but if there was 2” between the bracket and clutch fork i would be surprised. Seems very tight. I’ll try she get a picture of it tomorrow.
hmmmm slave? i have the hydro 465 stuff... similar to the factory early nv4500 with external slave?
not sure I have pictures handy, but there is probably 2 inches of space between slave mounting surface and the dimple in the fork.
push rod is 3-4 inches long?
hmmm ok, i might be ok then..here is what i have right now, ignore the corrosion…had to put this project on pause for a year :surepal: i have about 1.5” between the slave cylinder bracket and the clutch fork
That looks about right. I just measured my 465 and it measures about 1-1/2”
o ok perfect, maybe it was the massive pushrod they sell with the kit that threw me off, thank u very much for taking the time to measure it, hopefully she’ll be a runner soon! slowly picking away at it as best I can.
Yeah no problem. This is on a factory’87 type hydraulic clutch setup. I would assume you may have to cut to fit the pushrod from aa. I haven’t looked into their kit
