B
Bent77
Guest
Meh, o ring the block
At the end of the day, I have the same complaint about both rigs. Neither of 'em has enough doors.![]()
I'll sell ya a diesel burb
. I don't remember what year and such yours is?Have you thought of keeping the pickup but selling both the burb and cucv for a burban in better shape? A pickup is always handy when you have a house.
I've seen some pretty decent 80s and 90s diesel burbans on ebay for under $7500. I've been looking for one for myself too.
I've been see-sawing back and forth for years now.
Yours is very close to what I already have. You just don't have enough lug nuts.![]()
Yeah, I think of keeping the pickup every time I think of selling it.I've been see-sawing back and forth for years now.
My burb is in decent shape aside from the funny transmission shifting, so I don't think I need to upgrade it. Selling without fixing that is a money-losing idea, and once it's fixed I won't want to sell it.![]()
Should fix it so you can use it then![]()
That's the plan, Stan.
Unless it really is worth $7500 to someone, then I'll gladly cash it out and start from scratch.![]()
In the month that I've just been looking Ive seen some go stupid cheap and others go for a lot. Just recently saw an 85 3/4 4x4 6.2. Had power locks but manual windows. No rear heat or a/c. No third seat either, not even the mounting points. Was supposedly all orginal went for 20,000. Crazy.
..mine sounds like a stonecrusher until you reach 50 mph or so..A quiet 6.2 ?...it must have stalled!.....mine sounds like a stonecrusher until you reach 50 mph or so..
The 6.2 in my '85 Burb is much quieter than the pickup--I bet the injector pump timing was advanced on the pickup,I have never looked--or the Burb might be retarted ?..
The voltmeter on my dash sometimes refuses to go over "half way",fools me into thinking its not charging,until I give a dash cluster a firm whack,then the needle jumps up to 13.7 or so where it belongs..
Noticed the oil pressure was lower than usual too,till that whack got the oil pressure gauge to go up a good 10+ psi..
I'd check the plug on the alternator for loose connections or rusty tabs on the regulator where it plugs on--poor connections there will make it charge goofy because its not getting the proper input to tell it if the batteries are low or not..
