InjectorRx called. Injectors were clogged pretty good and it took a second soak and some harsher than usual chemicals to clean them out but they are where they need to be and good to go. Little luck, I'll try to crank it Sunday.
Throttle body back on. Just need one vac line, fuel filler hose, 4 clamps tightened, fuel pressure gauge installed, hook up a battery, add some gas, and twist the key.
