While replacing my leaky intake gasket, things were going really well. Too well.
As I made my first torque pass at 20 Ft/lb, the rear passenger bolt stripped. There was a bracket under it so I removed the bracket and torqued it to 20 ft/lbs. My second pass to final torque at 30 ft/lbs went well on the first 11 bolts. I just couldn't convince myself to try number 12 again so it remains at 20.
Should I :
-run it as is and see if it leaks
- remove bolt and drill a deeper hole to extend threads and use a slightly longer bolt ( is this a blind hole , and how far can it be/should it be extended if it is?)
-remove bolt, drill and place helicoil ( again, blind hole so no shavings?)
-drill and tap to larger bolt
-remove intake first and then one of the above ( obviously necessary if hole goes through to lifter valley)
Also, retorquing after heat cycle is recommended, is this ok if thread sealant was used or will the sealing be compromised?
Thanks for any help!
Should I :
