My buddy and I are gonna try and get his 74 c30 running next weekend, I think I know what all needs to be done but wanted to get input and see if I'm missing anything... Has a 350/sm465, been sitting for 5-10 years, was running and driving fine when parked. Here's what all I'm thinking to get it running.
-Clean/rebuild carb (q-jet)
-new oil and filter
-New spark plugs and wires
-While plugs are out, soak the cylinders in wd40
-Gonna use a gas can with a gravity feed line to the carb so dirty fuel lines/tank/bad fuel pump won't be an issue
-turn motor over a few times by hand before cranking
-new battery obviously
And here is some maybes that I was wondering if should be replaced before trying to crank
-starter
-coil
And that's about all I can think of.
Tall let me know what you think, and any advice you might have, let me know if I'm missing something.
-new oil and filter
-starter
-coil
