Engine:
2007 5.3L LY5, 218/227( have to go check the sticker on my toolbox to be sure) @.50 523/524 lift Stage 2 summit cam with trickflow .600 lift springs IIRC. Not horribly specific but just laying out the engine specs as to it being a mild motor with a freshen up.
When i uploaded the base tune for the ls in the terminator x max it fired up, it runs and all seemed good but after doing research into some guys like joes garage/sloppy mechanics and a few others on youtube who dyno test as a job, go over making tables for the LS and im thinking ive got some tweaks to do.. The youtube guys seems to know what they are talking about but when it comes to throwing timing at an engine up high and target AFR's but i dont want to damage my engine, obviously chances of that rise with timing advance and leaning out fuel for power, but im not trying to squeeze out 15 hp to kill an engine... but 17 miight be worth it..
If anyone on here can input or point me in the right direction thatd be cool. I know theres others on here about to do the holley terminator x too. Theres lots of info on other forums but i give ck5 all my forum time and have never found bad information here.
Few things ive picked up so are seem to be:
Set the AFR first and get it to idle close using the preset fuel base map and learning features if needed.
Then Advance timing at idle from 16-18* upwards to find the highest MAP while getting the lowest idle. From some information i found it suggests for medium cams , try within the range of 18-22 degrees of advance for a steady idle.
This is the AFR table i made with no revisions yet with the truck running but just based on info i had collected. 14.7 is Stoich but the .7 isnt as important apparently..
. A few guys i listened to said that with cam swaps sometimes they will idle best at 12-13:1 so dont be afraid to go that rich at idle if need be, so i figured id go rich and lean it outwhere its needed. The reason im motivated in this is the truck idles, but not great and i can definitely tune a less a loopy idle. WOT is apparently good at 12 and the power gains leaner arent worth the risk. Hoping to get out and load this on and see how it idles. i just auto filled the rows and colums to blend them for as rough starting point.
