You've got a lot of specs, and what you don't have is probably available (finding reputable/repeated L31 head flow specs has been tough), so have you used something like desktop dyno or anything to game out the parts? Would make a lot of sense if you plan on using components later, in a 383.
I forgot the 383 part, I wouldn't think of TPI with a 383 personally, although I know some have, the limitations of TPI will hinder the motor, and if thats the case, whats the point of the larger motor?
You might be able to do an LT1 intake swap, etc., etc., but that too starts to be a lot of work. When working with the Gen1 SBC, I think it's prudent to stick with heads that use the "old" intake bolt pattern, as there are more parts available (mainly heads, but intakes too) for them. Aftermarket heads with the non-Vortec ports flow as good or better than Vortec's, so that's not really a factor.
