GRINCH
I've done a body swap - it wasn't too terrible. the difficult part is figuring out how to lift the new body up high enough to get it onto a frame that's sprung with no weight on it! i ended up hanging mine from a cherry picker and a rafter-hung geared engine hoist. i attached at the cage - which may not help you. just TAKE YOUR TIME. those blazer bodies aren't light, and they'll hurt/kill if they fall on you.
I read up about how many people it takes to lift a blazer body - lot of people said 5 big guys would do. Guess I don't know the definition of big because we had 5 guys and we were lifting a topless, full convertible blazer body with no glass and no tailgate and we could hardly get the damn thing off of the trailer. let alone lifted high enough to get it onto a new frame!
additionally - i am surprised to read that you feel you have too much gearing for the snow. i've never experienced that, and everyone i see always wants more gearing. the guys that go the farthest in the snow around here have dual tcases and are engaged in SUPER low so that they simply crawl ontop of the snow instead of spinning tires. the way i see it, the slower you start, the less likely you are to end up spinning the tires and losing traction. the best snow rig i've ever seen had gearing so low that you could see the individual teeth of the gears engage by looking at how the tire was moving.
what's been your experience with that? can you elaborate/explain?
We were planning on 5 or 6 people to help swap it out. I may bring them to a friends shop that has a hoist to make it easier.
Snow wheeling and my gearing.
I run a 700R4 w/3.06 1st gear and a 241 with 2.71 Low, 4.10 gears with 36" tires.
In 4 high in deep snow with the tires aired down I can't get the truck to move once stopped in the snow. In 4 low no matter how hard I try not to spin the tires just break loose. Like the motor has too much torque or too much gear. Unless I'm way off and confused ,, If I regear to say 4.88's it will help with 4 high but make 4 low even lower and easier to spin
I used this calc. http://www.grimmjeeper.com/gears.html
4.10 gears puts my crawl speed at 208 Feet per minute
4.88 puts it at 175.
