dirtwarrior17
Banned
what'd he do
84_Chevy_K10 said:I don't know what you're talking about, the engine in my truck right now still has crosshatch on the cylinder walls.
hahahaha LOLTBI was by far the best mod I've made so far. Though it be a stock 87 tbi setup on my old 350 with headers, air gap intake and a rather large cam (that alot on here...or was on here told me would never work) I love it. I don't know if its the throttle response or if I gained horse power but it feels about 3 times stronger than my old carb (honestly). I'm still using the factory chip but I will eventually have one burnt. TBI really woke my rig up. I now also grin everytime I stop on an incline and then give her some pedal. She no longer lets me down, only takes me up.dyeager535 said:Tim to be absolutely honest and whether this is off-topic I'm going to say it anyways.
If you can live with your Q-jet, do so. With your application, if a carb isn't cutting out on you, or causing other problems, IMO, swapping to EFI just isn't worth it.
Don't get me wrong, I love my TPI, and it runs great. I won't be going back to a carb, ever. Heck, the new motor may have tons more power than it did with carb (guess it did blow my gov-lock up) but the truck sat so long between the two, and I didn't do a before/after dyno test, so it's really impossible (being honest here) to know what kind of difference the injection made. Besides the fact I added headers, roller cam, and the engine is nice and tight.
The motor is strong, it runs good, (not ideal, chip burning and new injectors are on the horizon of course) but to be honest, the Q-jet when tuned right, ran just as well for me. For a daily driver, the choke sometimes sucked, and so on, but if it was just a trail rig, I really think I'd hold off until a carb just doesn't cut it. The amount of money required to swap over (like the $2200 Edelbrock) is just an obscene amount if you are going to replace something that works ok already.
CyberSniper said:A used LS1 costs around $3,000. A brand spanking new LS2 costs $6,500. To make crate LS2 power you'd spend the same amount of money building a 383 cast iron smallblock (heads, machining, forged internals, fool injection). The LS2 makes 350ftlbs by 1200rpm BONE STOCK. The LS1 made 310ftlbs at 1200rpm. GM's LS1-LS2 computers are the best in the industry and people are running them running the world's lopey-ist cams (640hp normally aspirated).
OBDI has its limitations... if it were the shiznit more people would be racing using it. But in reality, it's a dinosaur. The processor alone is only good for about 7,000rpm. The maps are limited. The barometric sensor isn't good enough. I'm running it, but in its stock form.
Spending money on old technology, especially the coin some of you guys are talking about, is just plain crazy. By the time you can burn your own chips for an OBDI setup and get all your stuff you can buy Accel's DFI.
CyberSniper said:Next, you've got TBI. I bought an entire TBI 305 pickup for $125. TBI is only good for 325hp because the biggest two injectors can only support 325hp worth of fuel.
dirtwarrior17 said:gonna have to give you the buzzer on that one....there is guys over at thirdgen.com running my setup making 400 hp...
Costed me 700 for the holley tbi, manifold, and pump and its gonna be another 400 for the prominator and labtop...
i don't know what accels dfi costs but 1100 bucks for 400 hp isn't bad at all.
dyeager535 said:And they are. Don't know what you consider racing, but 10's and 11's on these dinosaurs isn't bad. I'm not a racer myself, I've never seen nor heard of an RPM limit based on processor speed. Stock, rev limiter on 1989 MAF cars was about 5900RPM. Again, I think a lot of this is going to come from the fact that the modern engines start with better parts than the gen1 SBC could ever dream of. Don't forget, the TBI ECM's are slow even compared to the later MAF ECM's.
dyeager535 said:So $250 for a 305 TPI (your situation) and $300 for chip burning stuff=Accel DFI?? I don't see how in ANY injection setup you can accomplish a "perfect" tune without spending the same amount of time. The later the motor, the more complex the process has to be, especially if we start talking about quad O2 sensors, MAF and MAP on the same motor, and so on. The hardest part of tuning is getting it right across the board. Whether LS1 or TBI, it's going to take effort to figure out what timing is best, fueling, etc.
dyeager535 said:IF you can get a 305 setup for your carbed engine for $250, wouldn't the expenditure be WELL worth it compared to getting an LS1 or whatever at $3000+? You say it yourself, it's about the dollar. Even giving $250 more for parts, is the $2500 difference (for example) worth it to the masses for the power (and problems) that you would experience with an Lx motor?
dyeager535 said:Not to mention, in the realm most of us talk about, low end torque is where it's at, not 7000+ RPM shift points. I'm sure some of the mud guys could really take advantage of that, but many certainly couldn't.
dyeager535 said:Everything is evolutionary, and on the EFI timeline, TPI is a ways back. Just not as far back as carbs and TBI, and not so far back to be irrelevant or unuseful IMO. There is better out there, always will be, but again it comes down to how much money do you have to go fast.
dyeager535 said:Unless you've used LS1 edit, at this point I think both of us are talking out our rears, since *I* don't have experience with using older ECM's to race, nor have I dealt with the Lx motors at all.
TPI is merely batch-fire TBI with MAF and eight injectors instead of two. OK, it's a little bit more complicated than that but essentially it's true.
A 2 barrel TBI setup can't make more than 325hp without buying $250 injectors. The largest production injectors ever made for a TBI220 were 100lb/hr ones. You can buy ones up to 200lb/hr but it doesn't matter since a large bore TBI220 can only flow 750CFM. Doing the math, you're limited to 325hp using two 100lb/hr fuel injectors. A 4 barrel TBI setup is good for 650hp... 4 injectors.
