That's another problem I have... I want my "small" gauges to all be 2 5/8". Some gauges aren't available in that size.
I'm looking at the Sport Comp series. The Sport Comp II series doesn't have anything in 2 5/8"...
Even then, the Sport Comp series has a few compromises I'm not happy about. I wish they'd offer a generic set with interchangeable faces so you could piece together a complete kit with everything you want.
I want the following... Mounted in Ryoken's dash bezel:
5" in-dash
Tach (0-10000rpm)
Speedo (Electric 160mph)
2 5/8"
Left side of dash:
Fuel (Electric/Short Sweep)
Fuel Pressure (Electric/Full Sweep)
Oil Pressure (Electric/Short Sweep)
Vacuum/Boost (Mechanical/Full Sweep)
Right side of dash:
Water Temp (Electric/Short Sweep)
Trans Temp (Electric/Short Sweep)
Voltmeter (Electric/Short Sweep)
Ammeter (Electric/Short Sweep)
I don't want a 10000rpm tach. 0-6000rpm would be fine, but I can't get it in a matching series. 160mph is a bit excessive as well for the speedo, but again, no options. I could get the mechanical speedo in 120mph, but I want all electric. I'll consider mechanical if I can use it and still have a VSS of some sort in there, as I'd like to add cruise control at some point.
I wish all the small gauges could be full sweep electric... Oh well.
