Only way to know if they WILL work, is to either get a response from someone that has done exactly what you are asking, or just wait until you get them. Measure the thickness of the spring pack on your truck now, the new ones, and the amount of threads leftover on the stock u-bolts as-installed.
I don't believe GM tended to leave more than about one inch of "unused" threads.
My u-bolts are wrecking yard-used, the rears have been on there over two years, (the previous were also re-used, lasted 4 years until I swapped to the 14SF requiring different u-bolts) the fronts have been on there since 2001, all get checked for tightness regularly, and haven't been loose yet. I don't put a lot of miles on it, don't tow, and don't wheel hard, but when I drive I don't drive it easy.
In good shape, no reason you can't reuse them, no different than any other bolt on your vehicle that you re-use. Lug nuts, caliper bolts, drum brake backing plate bolts, you name it. All under heavy load, all the time, just as big a catastrophe if they fail on the road, I doubt most replace those every time they monkey with them.
