I know some rental vehicles are setup to always be in tow/haul mode everytime the key is turned on .
HP Tuners only does engine and transmission, it doesn't do body modules or abs stuff including tpms.Is there any hand held that will do it? (Just wondering)
HP-tuners is probably the best way to go I guess. Given the price point.
I want to change my TPMS sensor settings also.
It's what, $200 per vehicle for extra credits ?
A credit is $49.99. To tune a standard all-in-one PCM is usually 2 credits, which for Chevy is up through 2016. As the vehicles get separate transmission controllers, etc, you need more credits. 2017-2019 or '20 is 4 credits and the newer ones take 8! https://www.hptuners.com/vehicles/gm-tuning/. So it's about $500 to get your first vehicle tuned and about $100/each after that.Is there any hand held that will do it? (Just wondering)
I know this is true in V10 U-Haul trucks. I don't think it's a good solution for a regular driver, though. GM has some pretty aggressive engine braking programming for tow/haul in anything new enough to have more than 4 gears. I wouldn't want to deal with that running empty. I think you want to maintain 2 tables, but bring up some pressures, shift points, lockup behavior, etc.I know some rental vehicles are setup to always be in tow/haul mode everytime the key is turned on .
Only the 14+ trucks have the temp regulator valve. I'd look up some write ups on bypassing it, as I believe you can do it for free if you flip the plunger or something.They make this for that cooler bypass issue .
Think I'm going to pick one up.
My other one is an '11. Is that an issue with that era also?
TransGo - 6L80-CLR-BYPASS - Cooler Flow Bypass Delete Kit
An easy, no-hassle cost-effective drop-in Cooler Flow Bypass Delete Kit for General Motors 6L80, 6L90, 8L90 and Allison transmissions.transgo.com
