Aha, the mysterious brakes don't work ??? ***Updated***
txfireman110
San Angelo, TX
Aha, the mysterious brakes don\'t work ??? ***Updated***
Put the 10/12 bolts out of K5 under K30, and this is where the problem begins......my rear brakes are NON-EXISTENT, which is strange, because I rebuilt them not long ago, and up until the swap, they worked great! I see two possible problems..
1. also swapped master cylinders out of vehicles(K5 has 1 ton, K30 has 1/2 ton cylinder. would having the lines switched cause this????
2. There is a little "thingy" the rear lines go to and there was some kind of bracket that just attached to the 14bff originally. Would eliminating the "bracket" cause this????
What's my problem???
***Bypassed the "bias valve" thingy /forums/images/graemlins/screwy.gif the bracket goes to, and it didn't seem to make much difference. Does the E-brake have to be adjusted first??? I thought you got the brakes good and then did the E-brake, but /forums/images/graemlins/dunno.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif***
Thanks
/forums/images/graemlins/k5.gifBrandon
Re: Aha, the mysterious brakes don\'t work ???
2. I forget he technical term for that bracket, but basically, it adjusts the brake bias (front to rear) based upon how much of a load is placed on the rear of the truck. Like if its got a heavy load will place more braking on the front or rear (cant remember which way it goes). But if you didnt hook it up, it may be sending all the braking force to the front.
[ QUOTE ]
[/ QUOTE ]
Agreed.
John
Re: Aha, the mysterious brakes don\'t work ??? ***Updated***
small chance..
but a few other members and my self mounted our calipers on the wrong sides, it in turn puts the beader screw all wrong and ya get no breaks... /forums/images/graemlins/doah.gif
other thought is your diaphrame is out on the booster, see if you also have vaccume going to it?
Listin for a hiss or air sound when you press the pedal,
good luck /forums/images/graemlins/waytogo.gif
supersize75k5.....
don't have discs, just the old drums (recently rebuilt), and I put a new master cylinder on it to drive it to the shop so it has less than 100 miles on it and worked great before axle swap.
I'll check the vaccum booster!!
Adjust Ebrake first.. That is the star adjuster at the bottom. A slight drag is what you want.
John
