im looking for a set of ak 57 arms-the piece that goes between the spring hanger and the spring- or the measurements for them.i dont need the whole kit as i have springs already.thanks
. These were all over in front of me this weekend . Two trucks ran with it this last weekend . Pics and measurements would of been easy . FWIW , I even know where a poor old set is crying right now , because someone doesn't wheel it . That set doesn't deserve to just sit there all lonely while the kid that owns it lets it sit there
i did. but havent recieved them yet and was bringing to the top as a reminder and to see if somebody happened to have set they werent using.pauly383k10 said:Whats so hard about PM'img Marv ( the inventor ) , or one of the AZ guys , who knows maybe one of us can walk 50 feet and snap a pic. These were all over in front of me this weekend . Two trucks ran with it this last weekend . Pics and measurements would of been easy . FWIW , I even know where a poor old set is crying right now , because someone doesn't wheel it . That set doesn't deserve to just sit there all lonely while the kid that owns it lets it sit there
)az-k5 said:Also, [noted sarcasim]
If you tow a trailer with it you will die... and take out a bus full of nuns
If you go down a hill with it you will die... and take out a bus full of nuns
If you wheel hard with it you will die... and take out a bus full of nuns
If you daily drive with it you will die... and take out a bus full of nuns
This should sum up the last 4 years of the springer suspension debate.
(I really should stop replying after 11PM or I am probably going to get a nasty gram from a mod by x-mas)
Your design is a heck of a lot better than revolvers are, and somehow I have managed not to kill any nuns (let alone a bus load!) in the several years I have run them.
My bad... I owe you an apology.would like everything but the springs.thanks.Mudgod said:What all do you need? I'm not using my anymore.
marv_springer said:Pauly does have a set he may sell tho....
Marv
I'm keep the shims that came with it, you can have everything else. Likes like the bump stops, shakle hanger, and the arm. $50?sledheadak said:would like everything but the springs.thanks.
marv- not a problem resent pm . thanks
