think so. if I was going to go that route I would use my 09 f250. even with a long wheel base I took it into some areas I shouldn't have. it doesn't exactly turn on a dime. that's why I bought the Willy's. looking for something in between
Isn't that like a 60k dollar truck?
I my case, NO WAY!!!! think so. if I was going to go that route I would use my 09 f250. even with a long wheel base I took it into some areas I shouldn't have. it doesn't exactly turn on a dime. that's why I bought the Willy's. looking for something in between
It still sounds quite expensive to be smashing into trees. I imagine that contributes significantly to a depreciation in value.
I quoted the wrong post on the last page by accident. I went and fixed that post.
Back to the Burbs.............
A 90s bronco might not be a bad choice. Rear seat area is a little lacking, but they're pretty capable stock, very reliable, simple once you get used to the ford aspect, and at least around here, they're somewhat cheap. Plus there's a huge aftermarket for them.
With a ****ty front axle.
Martin
Martin
Yes. I cannot argue there.
However, You also have something that is possibly much newer, if an auto it's electronically controlled with OD from the factory. An axle swap was already brought up, putting a 44 in one isn't too hard from what I've looked up. I do believe that requires a four inch or so lift, IIRC.
Martin
The four door broncos are pretty awesome. I would be looking four doors with kids and what not on a trip like that. I know they are not easy to find, but they do pop up once in a while.
the coil sprung ttb stuff isnt bad, actually none of it is as bad as it is made out to be, and besides, everything needs a 60 anyway.
