I thought id post this seperate since i added some into the 52 shock thread i did in the past, this is the whole swap with 53 inch alcans. I bought a set of 53 inch front alcans custom made for a k5, they make about 6-7 inches of lift. I used 7 inch shackles and moved the shackle mount to under the front edge of the body mount. The springs are made to keep the axle basicly in the stock location if you leave the front hanger in the stock position, the center pin is set accordingly. I had to cut some of the body mount to mount these and so when they swing they dont hit. In the pics the shocks are old and too short, the shackle bolts are too long and have to be cut, the pinion angle is at zero and ill shim that soon, also the shaft is way too short and ill be taking it off. The shackles are at 10 degrees but the truck has to settle and i have to drive it some to help that. Right now it sits about 1.5 higher than my superlifts. The bumper to the groung was 37 now 38.5, taking a inch off of shackle length and it settling should bring me to where i want.
I might plate the frame with 1/4 plate and move the shackle mount hole to between the two(the stock and the new one) That should give a 30 degree shackle angle...
Heres some pics of my swap... the ground isnt level where its parked in the pics...
