ALDLdroid
Its behind the glovebox, but its upwards at the top. Remove the retaining piece and the base bracket stays in place.
Yep. The bracket is bolted "under" the dash pad, the sheet metal that the pad rests on top of. Behind/above the glove box.
Red Devil River
I am looking at ordering the BT aldl adapter and the app. Two questions.
1. I have looked with no luck. where is my ecm for a 91 burb 5.7
2. The app says make sure you have the Adx file from tuner pro before purchasing. I can find the xdf but no adx.
3. I plan to use BT to my tablet but tuner pro well be on a Older laptop that only has usb. I am guessing I could save the files on the tablet then transfer them over to laptop?
I used the videos from Red Devil River, the maker of the bluetooth adapter I use to convert files.
http://youtu.be/IR_TKApiq48
